How do input bunkers or penalties in Garmin golf app
I have the CT10 and Approach S60  How do you add bunker shots and penalties to the watch and to the app
  • Penalties you add on the watch at the end of each hole. Watch will ask (or show you a score) you update this first.
    Example I take 3 shots to reach green, plus 2 putts, plus 2 penalties. My score for that hole is 7. Watch will likely show 5. you increase this to 7.  it will show you a Putts screen again correct or accept this. Next watch will ask for a penalty number. Works ok for me.
    Bunkers. I have an issue with this but its actually correct score wise. Bunkers are shown as a normal shot (in the graphic you will see bunker)  if the shot isnt counted at end of hole again you will have to correct the watch. Dont wait to edit in afterwards, as the graphic and scorecard are not aligned once the initial  upload done (MY BIGEST ISSUE AT MO).  If you take 2 shots to exit the bunker sometimes the CT10 misses the second shot because its from the same location, sometimes it need correcting again at end of hole. I have instances were the CT10 got both my attempts to exit the bunker but the graphic only shows 1 shot (scorecard reads ok).  They (garmin should be able to fix this as its a scorecard alignment with graphic issue.
    On the hole my watch works well with the CT10. Its just the alignment of scorecard with graphic, which makes editing the graphic useless. Please fix this Garmin!
