Approach CT10 and S60 not allowing Putter to be added
My S60 will not allow me to pair my Putter and Lob Wedge - all other clubs have been paired and are working.
I have set up all my clubs in Gamin Connect under the "Gear" option, however my Putter and Lob Wedge does not sync across to my S60.
In addition there is not option to "add new Sensor" on my S60 even though only 12 clubs are paired.
Have anyone else experienced this ?
  • I have just done this yesterday, I had no problem adding putter and lob wedge to my S60.
  • I have had the same problem. Except that only my putter doesn't show on the list of available clubs. the response from garmin support did not help.
    they basically said delete everything and start over but begin with the putter. I then had to restore to default and try again. Still no putter on the list.
    I had same issue, go into your garmin connect on web, there you can select golf gear, in this section you can add a putter to your golf gear. Once you have done this sync your watch, then your putter should be there when pairing with ct10
    in this golf gear section you can add clubs and put in details like make, model etc.
  • Thanks. That appears to have fixed my issue.
    0 Former Member over 5 years ago in reply to Former Member
    I had the same problem. Just changed the length of my putter in Garmin connect, sync-ed and then I could see the putter also on my S60. Sometimes I wonder if this SW engineers ever test their work???
    I fixed the issue of my wedges, and putter not showing up on the club sensor list by editing the default name on the gear list on the garmin connect web page as the thread suggested on my garmin s62 watch. Thank you for posting this, I was very disappointed that I was unable to add my clubs with the CT 10 sensors yesterday before my round of golf.
  • I had been having similar problems - after some time I’ve found the issue, I had too many clubs in my ‘Gear’, remove any clubs that aren’t actually assigned to anything ( my connect had duplicates of every club ), re sync and your watch should have the all the clubs on it.
  • Had the same issue with my putter. I deleted a heap of clubs, eg. 58 chip, 54 chip, 58 bunker, etc and tried pairing again and it worked straight away. You just can't have too many clubs in your My Bag.
  • I believe the limit is 26 clubs.  I've discovered this by trial and error.
