Inaccurate Ball Flights
I have noticed several time where the ball flight does not match the data that is shown in the system. For example see the image:   The characteristics of a in to out path and a closed face to path means this should be a push draw, basically starting out to the right and move left. This typically happens with the driver/3 wood. Thanks for looking into this
  • I am returning my unit.  no matter what I do, the unit cannot properly measure backspin with my driver... I know from using g c three that my driver spin is typically twenty five hundred r p m or sometimes over three thousand.... No matter what I do, the r fifty reads under two thousand even on the cut shots hit low off the face.  i tried using different lighting, putting dots on the balls. I was using etc et. Cetera et cetera nothing worked.... And it appears garments, updates are not happening frequent enough for a unit that's been out for a year....
  • People seem to be missing this key point. You have to account for the side spin that the R50 has measured on the ball. That side spin will curve the ball. It reiterates the need for the face impact location to be shown which would make it far more obvious that the issue is with the swing and not the device.
  • Interesting. I can’t get mine to do anything but show a pull with these type of numbers. Face more closed to path with club almost straight.
    To me it’s a misread.
