R50 refresh
Does Garmin plan on supporting the R50 with software updates to make the product better and provide options available on other LMs?  For example:
1. Bag mapping.
2. Different colored tracers and the ability to track stats separately if a user has (for example) multiple drivers.
3. The ability to manually choose distances on the target range.
4. Update the app.....please.
  • The only option on your post that is not available is the bag mapping option you mentioned in number 1.
    2. You can create multiple drivers, and to change the color simply change the club type to a different non-driver type of wood not already in your golf bag (2 wood for example) and nickname the club "Other driver" etc. This will change the shade of the club on the tracer coloration as each shade of wood is darker or lighter in hue as the type changes.
    Note: Shot opacity also has been updated in the previous update to allow better differentiation between shots of the same club type.
    3. You can manually adjust the distances on the other range profiles in practice mode. Distance range is not designed for targeted practice, Distance Range designed to gauge distances for each club hitting shots into a wide open area without predetermined amounts as there are no flags or markers other than viewing in overhead mode to see the shot dispersion.
    I will get you added to the ticket in-review from others wanting bag mapping but the other options you would need to either change the practice map being used or the club type being used.
    Our last update to the Approach R50 (Version 4.10) offered a ton of new improvements and features released 2 months ago. The Approach R50 is still supported for updates.
