After the 3.80 update my unit has a difficult time picking up high lofted wedges. If I move the ball to the top of the hitting area close to the unit it seems to work.
Updated June 5th, 2025:
Software version 4.10 and GLM 3.9.0 is now available to 100% of Approach R50 users.
This update contains improvements for chip/pitch shot detection (club metrics for slow swing…
The update has very much improved detection at very slow swing speeds. Thanks!
The problem first showed up 6/16/25 during awesome golf. I'm pretty sure that's the first time I've done simulated golf since the update. It wouldn't register a 60ish yard shot with my 58, and after…
This update contains improvements for chip/pitch shot detection (club metrics for slow swing speeds will now be detected). This update also contains improvements with the consistency of club metric measurements.
Keep an eye out for the update showing available to install.
For more info on the new 4.10 software update and GLM 3.9.0 you can access the full change log through the link here: Approach R50 System Software 4.10 and 3.9.0 GLM Rollout
Thank you everyone for your feedback and for participating in the Garmin Forum community.
- Garmin Cody
I've had trouble since the update with the r-50 not registering 50-90 yard wedge shots with my 54 and 58 degree wedges. I can hit 10 in a row and it not read a single one. Shorter pitches and chips read fine. Also all irons and drivers read fine.
Okay can you please specify which mode you are using? Home tee hero...Practice mode...or are you using one of the 3rd party compatible software connectors e6 Connect, Apex, Awesome Golf, or GSPro?
The problem first showed up 6/16/25 during awesome golf. I'm pretty sure that's the first time I've done simulated golf since the update. It wouldn't register a 60ish yard shot with my 58, and after a few attempts I tried my 54 with the same result. I ended up using a 49 to make the shot. The next time it happened around the same yardage, I rebooted my R-50 and tried again. It still wasn't registering the shot.
So, I went into practice mode on the range and tried it and it still wouldn't register 1/2 to 3/4 swings with my 58. Full swings and chips were fine. Also other clubs registered every time. My 58 and 54 it's like I wasn't even swinging. I verified it was green and ready and I have a spot light on hitting location.
I went back into awesome golf and continued to have issues with the longer partial wedge shots.
My r-50 has registered every shot up to this point (excluding some missed chips before the update) with 1000s of balls hit. I'm very happy with my monitor so far.
Thank you!
Still have this issue with wedges not reading, anything from 30-100 yards. A lot of times I have to hit 15 wedges in a row and then just punch an 8 iron. Happens in Garmin software like the range and in awesome golf. Crazy that there isn’t a calibration mode or anyway to check what the unit is seeing.
So you are not getting your yardages and spin numbers on wedges? No ball data at all?
We are getting absolutely nothing for 99% of high loft/ high trajectory. Starting with my 60° through my 9. Through a ton of testing it seems as though if the VLA is on the higher side coupled with a higher swing speed it won’t pick it up. More often, but still rarely, it will capture for a chip so high loft, lower speed. But I LOVE my sand wedge and a well struck wedge currently doesn’t register.
Putts are increasingly sporadic.
