Hi there,
is it possible to use an iPad as external display?
Kind regards
Information on connecting the Approach R50 to an external display, and the requirements for the connection are outlined on the Garmin Support article linked here: How Do I Use the Extended Display Feature on my Approach R50?
The Approach R50 connection display is as outlined below:
If your projector, TV, or monitor has an HDMI® port, you can use an HDMI cable to plug the Approach directly into the display.
If your projector, TV, or monitor has a DisplayPort you will need to use a powered HDMI to DisplayPort Adapter as well as a DisplayPort cable. This type of adapter requires a USB power source to be able to function.
We have a main thread for this topic discussion on forums post linked here: When I put the hdmi lead from my projector straight into the R50 there is no picture, it can’t be the lead as it works ok with my iPad. Any help?
To avoid duplicate posts, and to keep all of the conversations easily accessible in one place, please comment on the main post linked above for this topic, and per the Garmin Forums Terms of Use this thread will be locked to
