Hello!
Does anybody know if there's a protective case for the R50 available?
Garmin or Third Party vendor - anything would be fine
Thanks!
Hello!
Thanks!
The only option from Garmin is the case included in-box, as the unit is designed to be set up without any additional protective accessories.
I have submitted a ticket for this request for those wanting options for protective accessories that can be attached while using the features on the Approach R50.
Those interested in accessories becoming…
I use a 3mm acrylic sheet, size A3, in front of the R50 box. If it is resting at an angle, as shown, I don't get any misreads. If it is more vertical then reflection is an issue, and it sometimes misreads…
Please add me to the list
Plexiglass box that just covers the camera area would be good. Doesn’t even need to be a box.
I found and bought one on etsy. It arrived in 3 days and I'm happy with it thus far. Just search for Garmin R50 protective case and you should find it.
The protective case has cutouts where the cameras are located. Would this still affect the performance?
Hi,
couldn't find it - would you may have a link for me?
Here's the link.
[Link Removed] - Terms of Use
Thank you very much!
update: backpack cooler received and prepped. Ready to hit!
I just ordered a couple backpack coolers from Amazon to try out this weekend. The dimensions look promising and the front pocket should be able to be cut out for the cameras. There is no way I am letting the neighbor kids use it without some protection from club strikes. I did submit an idea to Garmin to provide a front section on their case which could be detached easily to allow use while still in the case.
I have hit mine once with a shank and it didn’t do any damage. Was wondering however, if that plastic is replaceable if it does get damaged? Anyone know?
There is, on etsy. the bad thing is that it's heavy as ***, poor design, reduces wifi signal. we need a new option.
