hoping to have the graphics as good as possible. We are going to build our simulator in the next week.
I have a BenQ AH700ST set up with it and it looks awesome!
The HDMI connection must support 1080p to the external display and the dimensions are configurable depending on the settings/features offered on the display being used.
There is a very wide range of compatible display options/types on the market, and there is not one specific projector that is recommended by Garmin...as there are many options available that may work best for some spaces vs others per each setup.
Did you use an HDMI TX and RX plug in so you don’t need wires for the image projection. Also do you need a computer to set it up?
