Not tracking any shots at all
Haven't fired up the Sim in a while and last night i decided to download the new HTH. Everything was working fine for the first 15 minutes, then my Garmin R10 did an update to the latest firmware in the middle of a practice session.  The light started flashing purple really fast.  I never seen that before and figured out that it means its doing an update.  Everything seemed to work fine for a few more shots.  Then all of a sudden HTH would not track a single shot.  Tried PW - 5 iron, full shots, half shots, didn't make a difference.  The R10 light is flashing green, then red on the backswing, like normal, but nothing gets recorded to HTH.  I tried shutting everything down and restarting.  I calibrate the R10 every time.  Took about 50 shots after all this and it only recorded 1 shot after I moved the ball about 5 feet from the R10 and it showed its flight straight right at like a 90degree angle over the trees.  Very frustrating.  I'm going to try it again on E6 tonight and see if it is a HTH problem or R10 problem.
