Garmin R10 and e6 connection issues
I just purchased an R10 and I have the license/garmin free courses added in my e6 profile.  I am unable to connect the R10 with the e6 software following the Garmin.com instructions.
1. the R10 is on and blinking green
2. I have paired it with the Garmin Golf app
3. I open "other simulators" and select e6 in the Garmin Golf app
4. I have e6 open and pick the correct license, and go to add the simulator.  I have Garmin, Garmin R10 Direct, Garmin R50 and a couple other unrelated options.
5. I select Garmin and enter the Host and Port info in the Garmin Golf app, test connection fails every time.
6. e6 also appears to not be connected because the battery symbol is empty.  I have used e6 with another sim and it always would either be a battery with an exclamation point (not connected), or a green battery with charge level displayed.
7. I have noticed when I am in the configure screen and select Garmin and click Accept, sometimes e6 flashes a pop-up saying Garmin R10 Direct disconnected - does anyone know if that means it was actually connected?  I haven't tested hitting yet because it's 40 degrees outside currently.
Any tips?  Thanks!
