I have the R10 monitor, using the garmin app on android, connecting to PC with the E6 software.
I have successfully been able to connect to my PC (WITH MUCH FRUSTRATION) I have the IP4 address correct, ports forwarded, network set to visible, have firewall disabled etc & the app CONSTANTLY says failed to connect.
I can get it to connect to the PC by manually reseting my router and assigning a new IP address to my laptop and setting the garmin to that IP address, but when I leave my laptop for a day or two it stops connecting, the IP hasnt changed, the port hasnt changed but for some reason it will never connect. It will only work if I AGAIN reset my router and assign a new IP address.
I am confirming it hasnt changed using cmd ipconfig/all
Im starting to thing this is an app issue and not one with my router or IP
Please help
