when i start moving head, R10 turn into solid Red from green flashing, and 9/10 shots, there is no data picked up.
tried reset, re-installed the apps on iphone, no luck
thinking to return it
If you are using the R10 indoors, make sure you are using the recommended spacing suggestions, along with eliminating any environmental factors that interfere with the radar capture.
For reference on the spacing and setup suggestions, check the Garmin article here: Tips for Indoor or Outdoor Approach R10 Placement
To view the radar and troubleshooting FAQ, please reference the support page here: Troubleshooting Radar Features of the Approach R10
Typically the issue you are experiencing is due to the spacing of the indoor setup, or there is an environmental factor affecting the radar capture that needs to be moved away from the capture area, to allow the R10 to sufficiently capture each shot.
when start moving club head , R10 turn into Red ,, is that the expected ?
Yes, that is indicating r10 unit detects movement.
If no results are shown, i suspect one of two:
Swing takes too long to finish or swing is too fast.
