Ball to R10 Distance
How critical is the Ball to R10 distance set in the Garmin Range ?
1) I'm finding I need to stand about a foot closer to the net when practicing wedge shots to prevent mishits from going over the net.  Do I have to adjust the Ball to R10 distance for that foot of difference or is that not necessary?
2) If I use E6 Connect, I know that I should calibrate the R10 first, but in order to set the Ball to R10 distance I have to first enter the Garmin Range to do so. If it's a critical distance, that means I have to go back & forth between the apps to reset the distance between wedge shots & other shots.
