R10, Almost Golf Balls, Driver, 3 Wood
Has anyone found success hitting into a net indoors using the Almost Golf Balls, Driver, & 3 Wood ?  I can hit chips, pitches, & full iron shots & every hit is read on the Garmin Range. When I try to hit driver or 3 wood I'm lucky if 10 % of the shots are read. I'm not interested in distance accuracy. I'm just working on my swing path, club face, swing speed, etc.   Info that would be helpful is distance from  ball to net, distance from ball to R10, height of R10 tripod feet in relation to the hitting mat, the type of tees that you use & how you set them up, swing tempo, and any other factors that may help. Thanks.
