Will the 4.3 update provide different results if I use my normal balls against the RCT balls? How does it pick up what balls I am using?
If the R10 is using Titleist RCT's radar capture technology now with the 4.30 update, will it read by normal balls different than it used to or how did it change?
  • @9915216 I recently bought a dozen RCT balls. I have tested them alongside my usual Taylor Made TP5's in my home practice net keeping to all the recommended Garmin R10 setup data. I have to be honest, the only, and I mean the only noticeable difference is the spin rate with the RCT ball is down by around between 20 and 100RPM... the carry is identical as is all the other data ...  If anything it appears the RCT data is probably a little more consistent in its returns. It would be nice to know what others think.... :-)
  • I'm currently testing an r10 with RCT next to a GCQuad.  My results seem to indicate that the backspin number is just about dead nuts on compared to the Quad (+/- 50), but the sidespin still isn't lined up great, usually R10 reads less by about 1/2-2/3.  Based on last few strikes for example, averaging about 1500 side spin according to Quad, and routinely the r10 + RCT is picking up 500-800.  Pretty big difference.  I'm in SoCal and the R10 is setting elevation to about 700ft.  I don't know exactly what my elevation is, but setting it to 1800 seems to make the carry just about match with the Quad also within a yard or 2 usually.  So, numbers do seem improved with RCT, sidespin still lacking, but better.
