Whenever I use my approach r10 with the air conditioning on in my simulator room there is a lot of radio interference how to avoid it it is around 40 degree Celsius here so I cannot switch off the air conditioning please help
I had the same problem and this is what worked for me. I had to use something to deflect the air downward as it came out of AC. This made it quieter as well. It completely stopped my interference problems.
Will try it thanks
Hi did that work? I have a similar issue wit ha portable AC unit about 5 feet directly to the right of the garmin. I knew in front was bad because the app would tell me. I don't get interference warnings on the app but I do get a red steady light on the garmin 75% of the times and turning off AC unit fixes that. The R10 is on the floor and the air coming out of portable AC is 2-3 feet above unit
