Wind speed and direction - HTH and Range?
I'm wondering about when wind is applied to the shots and has an effect?  Can you please tell us if Wind applies on the Range, or only in HTH?
Also, if Wind can be adjusted for speed, which I believe I saw in HTH, then is it always using the direction it shows when you go to Weather Conditions setup screen?  Is there ever a changing wind applied such as when it varies it's direction, and is that measured from current wind conditions on a regular basis, and how frequently is Garmin Golf App measuring that?
I'm using HTH and Range in Garmin Golf App on an iPhone 7.
Thank you,
-Brett
  • First of all, golf app does not measure wind. Neither does the R10 unit.
    And why should it?
    If You're on a range, the measured ball flight will be affected by the wind. You want to add extra wind?
    When playing in garage or back yard it is possible to add wind condition, and then the algos will reduce or increase Your distance and dispersion based on that.
