Great update with the various driving ranges, ability to set weather conditions and landscape mode. Only thing that slighty has been made worse is that you're no longer able to swipe between the different…
Literally feels like Christmas morning haha
I only tested r10 at an indoor public golf sim running TGC 2019 using Uneekor eyeXO (which is mounted directly above the hitting mat. The r10 and Uneekor were almost identical readings. Very impressive…
Really? Even with the higher settings? 4500ft, 65% humidity, 85 degrees did the trick for me. May actually be too much
Yeap used your settings. Too hot for garage sim I can't swing anything higher than 5 iron. My 4 smacked off the ceiling after a few tries. I reset, remeasured and re-calibrated it seems better now!
I used this link but the app looks like the one downloaded from the play store. Is there anything that I did not notice?
The link is only for Android tablets.
Your phone will get new releases via Google Play and normally update automatically.
Your tablet will not.
OK we are good FINALLY! Moved to garage today. 6.6ft from Garmin (I set it to 7ft) and 9ft from net. 4500 elevation, 65% humidity, 85deg. Measurements are now pretty much bang on to my outdoor range sessions. Tried Garmin range and one HTH course nearby. We are good to go!!!!
Did anybody see the chance to verify - e.g. against a GC / Trackman - the suggested outdoor settings of - 4500ft, 65%hum and 85deg? For a novice (like me) it is still a tricky situation since I am not that consistent (yet).
Also since the TS stated the setting;
I only tested r10 at an indoor public golf sim running TGC 2019 using Uneekor eyeXO (which is mounted directly above the hitting mat. The r10 and Uneekor were almost identical readings. Very impressive compared to a $12k launch monitor.
