I see the post 'R10 not recognizing any shots....SN 6PN013XXX'. I'm not sure why this has been locked after so short a time. Mine is a 6PP, one of the suspect serial number ranges. Mine has a similar problem. I am fine if I set up in my office. Green remains flashing for several minutes. But as soon as I set it up anywhere I can play a shot, I struggle to get a flashing green, and if I do and then take a shot, then it doesn't record and the led goes flashing blue, or white or some other random combination of colours, flashing or not flashing. The ground is level, the distances are measured out. I was on 3.7. I now need convincing that this range of Serial numbers (6PP and 6PN) isn't faulty.
