Can users who are getting the right kind of performance from the R10 indoors, post pics of their set up please... Thanks...
I am trying to find the right setup like many others. It looks like the best performance I have is with 1,8 meters between ball and R10. The driving range mat is 7 cm from the ground so I have the R10 also standing on some wood of 7 cm high as well. I have the feeling the R10 measures 10-15 meters short on an iron 7 but this is the best I can get it. The distance between ball and net is 3 meters.
By the way. I have updated to version 3.7 as well
I have difficulty on gravel and would suspect that brick on the floor to be an issue.
Did u try covering the brick floor with a cloth or carpet?
Thanks for the tip, I will try this and update in this topic later.
It did improve, I did some more trial and error with distance of the R10, I have now exactly 1 tourstick between the mat and the R10 and getting the best (and acceptable) result so far. So now I will cover the whole area with artificial grass to have it look more nice (and to avoid having the balls bouncing back to much)
you all have such good setups. I have to swing outside into my garage until I get roof raised on garage
Thanks rlefig
