Strong Net Recommendation: Spornia SPG-7
I just wanted to pass this along, after working off a budget Amazon net that took too long to put up and down, I bit the bullet and got a Spornia SPG 7 with the side nets and simulator screen. I have seen others using this with the R10 and I think a few things about it are particularly well-suited for it.
1. The material is fairly heavy and may help with those who are finding radar issues hitting into a net.
2. The added side nets add a ton of protection in the 8-feet distance range, which may help with those who are holding back a little.
3. You can put it up and down in literally a couple minutes, maybe less for putting it up. I used the other net less because it was a hassle. The SPG 7 is literally a pop-up design with a couple support poles that just insert into grommets. I was looking for garage cage options and this does a better job. If I really thoguht I needed it, I could put a 7x10 net or tarp on the ceiling to fill in a full "cage," but I don't think it's necessary.
