R10 not picking up any shots.
R10 5 days ago everything was fine now everything is good green light flashing hit the shot light goes white. Hit power button it goes flashing green same results hit the shot goes white nothing recorded. Same place same setup can’t get it to work chat says must be above the level of the mat it’s been that work all along. Anybody else seen this?
  • Found the problem with help of Garmin support chat thanks Josh. I had to delete reinstall the app and go through the setup again. Don't know why this happened but it fixed the problem.
  • Thanks so much for this post. Reloading the garmin golf app has fixed my issue too. My R10 was connecting with my phone and working exactly as it should with leds BUT it would not pick up any shots at all. All good now after reloading the app. Thanks again
  • Just deleted and reinstalled and all is good again!
  • If you are experiencing this issue, please try following the steps outlined below:
    1. On the Garmin golf app: Select Menu> Garmin Devices> Press and hold the R10> Remove
    2. On the bluetooth settings on your phone: Settings> Bluetooth> Select the Gear next to the R10> Unpair
    3. Next please uninstall/delete the Garmin Golf app off of your phone.
    4. Clear the Play Store Cache: Phone Settings> Apps> Google Play Store> Storage> Clear Cache
    5. Turn off your phone, wait 10 seconds, Power it back on
    6. Reinstall the Garmin golf app
    7. Reset the R10 by pressing and holding the button for 30 seconds
    8. Power off the R10 then put it into manual pairing mode by pressing and holding the button until you see a solid blue light
    9. Re-pair your phone and R10 through the Garmin Golf app
  • One big THANK YOU for this. I was getting desperate because of this bug. Obviously there had to be some update problem recently. No other explanation for so many people having same issue at the same time. Disappointed
