- When outdoors does the R10 work with range balls, or are regular balls required?
Also, if regular balls are used, does the distance issue disappear?
either balls work, range balls tend to be 10-15% shorter than gamers. what I have found is that the older and more worn down balls you use, the more variance you get in flight distance, spin, and shape.
there has been a mention by someone that some radar units from other brands have issues with certain materials in the core of some brands of balls... not sure how true this is.
