This is a simply upgrade for any good developer , so why hasn’t it been done. Please Garmin can you explain why it’s taking so long.
BUMP!!!! We all need this!
There have been so many good and important feature requests but not a single app update and only one firmware upgrade since launch. It's definitely time for an update ;-)
If you're using an Android device, you can use this app to lock your device into landscape mode and it works pretty well!
https://play.google.com/store/apps/details?id=org.crape.rotationcontrol
works on ipad as well, even with a beamer. All you need to do, is to select screen tilt hold (slide down from top right corner and press the lock with a curved arrow) when you’ve started a course. After 1-2 seconds an additional pictogram will appear in the bottom right part of the screen, that shows a rectangular with a curved arrow. Press this and the screen will switch to landscape
