Is there a way to export "Golf Sim Sessions" data to a .csv or other file type to review on my Mac? Just got my R10 and I would like to explore the data a bit more offline.
Hello, this feature request ticket is still being considered and reviewed by our engineering team. In the meantime, we are continuing to add interested customers to the ticket.
I wish I could tell you…
Just want to point you all to my program R10Analytics that I wrote to analyse your Garmin R10 data. It will show you how to export your data from Garmin and import it in the program. I just release the…
Same, or at least let it sync to Garmin Connect like the watches do. We don't want to go through a clunky app interface post-round to see all our stats from sessions.
What problem did you have? You don't have to install anything yourself. Just download the R10Analytics installer and run it.
I did not have a problem. The club issue you talked about is a problem but i knew what clubs i had hit. I recommended your program to someone seeking help on the excel solution i suggested. Your program should work for anyone. I have not played with it enough to know how fine grained one can drill down.
If asked i would recommend your solution,
Hi from Spain. First of all, thanks for your work Mark.
I download version 0.50 and it works once, I have updated to 0.70 and now the program does not open for me.
I have Windows 11 totally updated and java v. 8-341.
What the problem may be?? I unistall several times and try to install again, but with the same result, don´t open
Thanks
I also updated to 0.70 and it does not open for me either. uninstalled and installed several times. .
I have this exact problem.
Im trying to run the latest v0.70 version of R10Analytics. Im still getting an unknown publisher warning when installing. I accept the warrning. When I run it, it wont start. SImilar to other users. Event log summary
Faulting application name: R10Analytics.exe, version: 0.0.0.0, time stamp: 0x62f0fb30
Faulting module name: Qt6Core.dll, version: 6.3.1.0, time stamp: 0x6298c2d2
Exception code: 0xc0000409
Fault offset: 0x00000000000103b8
Faulting process id: 0x5d0c
Faulting application start time: 0x01d8b1b2298ae2cc
Faulting application path: C:\Program Files (x86)\R10Analytics\R10Analytics.exe
Faulting module path: C:\Program Files (x86)\R10Analytics\Qt6Core.dll
Report Id: 4be01e3b-8a84-45fe-99dc-3091f97071a6
Faulting package full name:
Faulting package-relative application ID:
https://github.com/earl553/garminr10dataconverter didn't work for me, so I made my own python-script
Some people experience this problem. Sorry about that. It seems to have to do with some missing or wrong DLLs but it is very hard to figure out as I cannot reconstruct it. But I am working on it.
Mark
Hi Rob, you can add me to the list.
It’s really frustrating to go to each and every shot to see the data. I would like to be able to select shots and metrics to be able to compare quickly to see trends.
regards, Rick
@Garmin-Rob - is there any update on this topic? The silence from Garmin on this whole topic has been deafening. The whole point of the R10 is to practice and work on your golf swing and yet Garmin provides no way to see this data except as a singular shot - table view or easy export should have been done a long time ago but instead Garmin has gone silent on this topic and left all the users to figure it out - not cool.
