The device will charge from the laptop,
Laptop will not recognize the device for updating
The Micro USB cable being used must support both charging, and data transfer. The cable we include new in box with the G80 is about half a meter in length, is all black, and supports both data transfer/charging so the device drive on the G80 can be read by a computer.
Verify the USB end on cable you are using has a GARMIN logo stamped into it. If you do not see the logo on that end of the cable, you are likely using a 3rd party cable that only supports charging, and not data transfer.
Hello, yes using the cable from Garmin but still not finding my G80 device.
Need help. Thanks
Further solutions can be found on the Garmin Support pages linked below which offer in-depth troubleshooting per the specific computer system you are using:
If you continue to have concerns, please contact Garmin Support to discuss the issue with an expert to determine what else may be causing the issue.
