After every hole the G80 shows a scorecard for 4 players.\
I don't use the scorecard function on my G80, i would like to disable it, so it does not show up after every hole.
If you are referring to seeing all 4 players while you golf and you are using your G80 only as the launch monitor using the radar feature, only input score for yourself and when done, do not save the scorecard…
I will be happy to add you to a request to have the option to disable scoring within the Settings > Scoring menu of an Approach G80.
For any other Approach G80 customer that reads this thread, if you…
You can disable the scoring stat tracking feature by going to Settings > Scoring > Stat Tracking and setting your G80 to Off.
Yes, definitely please include an option to turn off scoring. Many people use alternatives to track their score - for example the Miscore app is commonly used by clubs in Australia. In this case, the g80 should ideally only be used as GPS device whilst playing. Thank you.
Is your G80's bluetooth on?
I keep the G80's bluetooth turned off when i play; it never asks me to input a score. Plus it saves some battery I think
