Hi,
I use the Personal API to build a daily coaching brief from my own data, and it has replaced an unofficial login-based
library for almost everything. Thank you again for adding daily VO2 max.
**The problem.** The Personal API needs one request per data type. A daily sync of the last three days needs a token request
and then one call each for sleep, HRV, weight, body battery, daily summaries, VO2 max, wellness activities and the activity
list, even though every one of those endpoints already accepts a date range. That is about 10 requests to collect a few
kilobytes. In October the API started returning HTTP 429 after about 47 requests in a day. That leaves little room for a
backfill, and a single retry after a network error uses up more of the allowance.
**What I checked (2026-11-16).** With a valid Personal API token, `POST personal.connectapi.garmin.com/.../graphql`
returns **404**. As far as I can tell, Garmin Connect's website uses this gateway to fetch several metrics in one request.
The same token reads sleep, HRV, activities and VO2 max without a problem.
**What I'm asking for.** Either of these would work:
1. **GraphQL on the Personal API host**, read-only and limited to the data the Personal API already exposes. One query could
then return a date range of sleep, HRV, body battery, daily summaries, weight and VO2 max.
2. **A single multi-metric daily endpoint**, for example
`GET /…/daily?startDate=…&endDate=…&metrics=sleep,hrv,bodyBattery,dailySummary,weight,maxmet`, returning one object per
day.
**Why it helps Garmin too.** A daily sync would drop from about 10 requests to one or two. That means fewer token exchanges,
connections and requests for Garmin's servers to handle, and fewer 429s and retries. Clients that make fewer calls also
have less reason to fall back to unofficial libraries that scrape the web endpoints.
**Related (optional).** These performance metrics also return 404 on the Personal API, which I'd like to add to a batched
query if they become available:
- `/metrics-service/metrics/trainingreadiness/{date}`
- `/metrics-service/metrics/trainingstatus/aggregated/{date}`
- `/metrics-service/metrics/endurancescore`, `/metrics-service/metrics/hillscore`
- `/metrics-service/metrics/racepredictions/…`, `/fitnessage-service/fitnessage/{date}`
- `/biometric-service/biometric/latestLactateThreshold`
**Questions**
1. Is there a way to batch reads on the Personal API that I've missed?
2. If not, would Garmin consider GraphQL or a multi-metric daily endpoint?
3. What is the daily request limit, so a client can plan its calls to stay under it?
Thanks for the Personal API. It's been reliable, and batching would make it much lighter to run.
