If I upload a metabolic age of 40, Connect shows the value in milliseconds with the unit years. This is for a Wyze scale integration I am building.
The uploaded FIT file uses the standard Garmin FIT weight_scale message:
| Property | Value |
| Message | weight_scale |
| Global message number | 30 |
| Field | metabolic_age |
| Field number | 10 |
| Base type | uint8 |
| Scale | 1 |
| Offset | 0 |
| Units | years |
| Uploaded value | 40 |
Value in Connect is
"metabolicAge": 1262277040000.0
Looking for investigation:
Whether the
metabolic_agefield is being interpreted using an incorrect unit or conversion factor. -
Whether the value is inadvertently being treated as a timestamp, duration, or milliseconds-based quantity.
Whether the defect affects all third-party
weight_scaleFIT uploads or only certain source types. -
Whether the issue is reproducible using the attached FIT file.
Whether affected records can be corrected and whether a server-side fix is planned.
