Missing sensor settings (crank length, footpod calibration, wheel size) in Personal API
Hello,
I am considering the Personal API (download-service) to pull activity FIT files for personal data tracking. While standard telemetry streams (heart rate, cadence, raw power, speed ticks) are present, I’ve noticed that critical hardware configuration, calibration metadata, and device information—specifically stored in FIT Message 147 (sensor_settings), Message 22 (device_used), and Message 23 (device_info)—are suposed to be consistently stripped or omitted from the api endpoints.
Without these snapshots we lose the physical baselines required to accurately re-process raw sensor streams:
1. Crank Length: Vital for pedal-based power meters (e.g., Garmin Rally/Vector) where torque is calculated from applied spindle force (Power = Force x Crank Length x Cadence). Without this snapshot, external software cannot verify whether reported wattage matches physical leverage, leading to systematic power calculation errors if defaulting to an incorrect arm length. This directly breaks multi-equipment workflows for athletes alternating between road bikes (170mm cranks), time-trial bikes (160mm cranks), and mountain bikes (175mm cranks), as we lose the ability to parse the exact hardware geometry used for that specific session.
2. Footpod Calibration Factor (Field 11): Necessary to account for non-linear biomechanical changes (such as ground contact time and flight phase shift) between easy recovery paces and high-intensity interval/race paces. Stripping Field 11 prevents post-processing from auditing whether pace variances stem from gait changes or active watch-side scaling adjustments.
3. Manual / Auto Wheel Size: Required to properly convert speed sensor wheel revolution counts into true ground speed and distance. Without the recorded circumference snapshot, we cannot audit wheel-derived speed against GPS ground truth.
Questions:
1. Is the removal of Message 147 (sensor settings), Message 22 (device_used), and Message 23 (device_info) from Personal API intentional due to new Api policies?
2. Are there any plans to preserve these user-configured sensor parameters and device metadata in Personal API endpoints so we can accurately evaluate raw power, pace, and distance streams across different bike/run geometries?
Having access to these physical calibration baselines is essential for maintaining mathematical fidelity. Any clarification would be greatly appreciated!
