I'm using a Personal API key to pull my own health and fitness data into a daily report. Every other metric I need is available, but I can't find VO2 max in any endpoint or in downloaded FIT files. It shows up in the Garmin Connect app and website, so the data exists on Garmin's side.
### What I checked
Using the Personal API (`personal.connectapi.garmin.com`) with a current key, I searched all response fields for `vo2` and related names in:
- `usersummary-service`: `/usersummary/daily` and `/v2/dailysummaries`
- `sleep-service`: `/sleep/dailySleep` and `/sleep/dailySleepSummariesByDate`
- `fitnessage-service`: `/fitnessage/v2/{calendarDate}`
- `biometric-service`: `/heartRateZones/v2`
- `userprofile-service`: `/userprofile/settings`
- `activitylist-service`: activity summaries (about 90 activities)
- `activity-service`: `/activity/{activityId}` for each activity type I have (walking, treadmill running, lap swimming, yoga, strength)
- `download-service`: `/files/activity/{activityId}`. I parsed the FIT file from a treadmill run, and it contained no VO2 max field. It did contain a `lactate_threshold_autodetect_enabled` setting.
None returned a VO2 max value. This repo's client also has no VO2 max wrapper.
### Questions
1. Is VO2 max available through the Personal API in some endpoint I've missed?
2. If not, is that intentional for the Personal tier, or could it be added (for example in the daily summary, fitness age or a dedicated endpoint)?
3. Are VO2 max, recovery time and performance condition intentionally removed from FIT files delivered through the API? I've seen reports that they are, but haven't found it documented.
### Why it matters
VO2 max is a core fitness trend metric, and the Personal API's stated purpose is access to one's own data. Without it, a personal tracker has to fall back on an unofficial login-based library for this single metric.
Thanks for the Personal API and this example client.
