Effort-Based Targets via SDK
Hi,
If I create a Swim Plan in Garmin connect, I can select "Effort-Based" Target (which is basically RPE) and select from the RPE numbers.
If I want to create a swim plan with a RPE Step, which WktStepTarget (https://github.com/garmin/fit-java-sdk/blob/main/src/main/com/garmin/fit/WktStepTarget.java) should be used?
Kind Regards,
Thomas
