Weight Rounding Error in Fit File
I sent a strength workout to the connect API, and the weight target for the exercises was 68.038 kg. I then tracked the workout using my Forerunner 255. The display setting was pounds, and the weight target was correctly set to 150 lbs.
When I parsed the fit file from the completed workout, I found that the weight was 68.0625 kg. This appears to be a significant rounding error and causes issues in my application.
Is there a known issue on Garmin's side?
