Can I use the FIT SDK to solve the upload problem with the following file?
www.vangeel.org/230729112320.fit
Already downloaded the SDK and did some file verification tests but did not see what's wrong :-(
Hi, nevertheless, I cannot upload the file (see screenshot).
There are 3 failures in your verification report:
Activity Message total_timer_time is Equal to the Sum of Session Messages total_timer_time Values - Level: REQUIRED Status: FAILED
Session Message Valid Message Index - Level: REQUIRED Status: FAILED
Lap Message Exists - Level: REQUIRED Status: FAILED
Could these failures be the cause of the upload problem?
					run your file through FitFileTools's section remover
it does not help :-(
					check this file 230729112320-fixed.zip
same problem, upload failed :-(
					Unfortunately I just deleted all rides from my GPS. I will record a new ride tomorrow and try to upload it.
Thanks for the help!
					Nope, download after upload is not available in the app :-(
