What is the proper algorithm to convert time_offset from fit file for negative timezones, to seconds?
Previously in our app we were using json files where time_offset value for negative time zones was just negative time in seconds (e.g. -18000). After switching to fit file, we started saving time_offset in the database in minutes (i.e. time_offset from fit file divided by 60). Unfortunately, no one expected that time_offset for negative time zones would be expressed differently.
Now in the database I have, for example, the x value, which I need to multiply by 60 to get the y value corresponding to the time_offset from the fit file. I need to add the y value to the timestamp from the fit file and convert the result to a 32-bit number. Then subtracting this 32-bit digit from timestamp, I get time_offset in seconds:
  x y timestamp sum 32bit integer time_offset in seconds hours
  (time_offset from our db) time_offset from fit file(x*60) timestamp from fit file y + timestamp sum | 0  "-(timestamp - 32bit integer)" time_offset in seconds/60/60
1 71582488.2666666 4294949296 1646575923 5941525219 1646557923 -18000 -5
2 71582548.2666666 4294952896 1667158354 5962111250 1667143954 -14400 -4
3 71582713.2666666 4294962796 1667140674 5962103470 1667136174 -4500 -1.25
4 71582773.2666666 4294966396 1661463139 5956429535 1661462239 -900 -0.25
5 71582787.3333333 4294967240 1647715116 5942682356 1647715060 -56 -0.015555556
This approach I found here: https://forums.garmin.com/developer/connect-iq/i/bug-reports/corrupt-time_offset-in-a-watch-app-fit-file-when-time-zone-is-negative however, it seems to fit just first two x values.
I also have some values in database which seems NOT to fit above algorithm at all.
  x y
1 1 60
2 43 2580
3 58.6 3516
4 59.01666667 3541
5 59.23333333 3554
6 59.93333333 3596
7 60.7 3642
8 61 3660
9 89 5340
10 118.6 7116
11 119 7140
12 119.2333333 7154
13 119.9166667 7195
14 119.9333333 7196
15 120.7 7242
16 121 7260
17 195 11700
18 281.0333333 16862
19 313.5666667 18814
20 719 43140
21 780 46800
Could someone explain what is the proper algorithm to convert time_offset from fit file for negative time zones, to seconds?
