example/decode.cpp doesn't show developer fields in sample FIT file [noob]
Hi - I'm a newbie learning the FIT SDK and have successfully used java, python, and C++ to decode FIT files.
I found that the C++ decode displays developer fields in examples/DeveloperData.fit but does NOT show developer fields in Customer.fit (attached).
In contrast python works on both, and fitfileviewer.com also shows the developer fields for both.
How do can I get decode.cpp to display the 16 developer data fields in Customer.fit?
Here is partial output of C++ decode on DeveloperData.fit -- note the developer field doughnuts_earned displayed with "On Mesg:"
% ./decode ~/Downloads/FitSDKRelease_21.101.00/examples/DeveloperData.fit
FIT Decode Example Application
On Mesg:
   New Mesg: record.  It has 5 field(s) and 1 developer field(s).
   Field0 (heart_rate) has 1 value(s)
       Val0: 144 bpm
   Field1 (cadence) has 1 value(s)
       Val0: 92 rpm
   Field2 (distance) has 1 value(s)
       Val0: 3710 m
   Field3 (speed) has 1 value(s)
       Val0: 35.344 m/s
   Field4 (enhanced_speed) has 1 value(s)
       Val0: 35.344 m/s
   Developer Field(doughnuts_earned) has 1 value(s)
       Val0: 3 doughnuts
In contrast here is the partial output of C++ decode on Customer.fit -- note that the 1st developer data field (wind_yaw) is displayed once.
Subsequent  "On Mesg" show no developer fields at all.
On Mesg:
   New Mesg: record.  It has 10 field(s) and 16 developer field(s).
   Field0 (timestamp) has 1 value(s)
       Val0: 1.02993e+09 s
   Field1 (position_lat) has 1 value(s)
       Val0: 6.25678e+08 semicircles
   Field2 (position_long) has 1 value(s)
       Val0: -2.43235e+07 semicircles
   Field3 (distance) has 1 value(s)
       Val0: 0 m
   Field4 (altitude) has 1 value(s)
       Val0: 120.4 m
   Field5 (speed) has 1 value(s)
       Val0: 0 m/s
   Field6 (power) has 1 value(s)
       Val0: 0 watts
   Field7 (temperature) has 1 value(s)
       Val0: 28 C
   Field8 (enhanced_altitude) has 1 value(s)
       Val0: 120.4 m
   Field9 (enhanced_speed) has 1 value(s)
       Val0: 0 m/s
   Developer Field(wind_yaw) has 1 value(s)
       Val0: 0 Record:
   distance:
      native: 0.000000
   speed:
      native: 0.000000
On Mesg:
On Mesg:
Record:
   cadence:
      native: 90.000000
   distance:
      native: 3222.210000
   speed:
      native: 12.251000
On Mesg:
Record:
   cadence:
      native: 89.000000
   distance:
      native: 3232.690000
   speed:
      native: 12.251000
Python successfully decodes both DeveloperData.fit and Customer.fit and reports the data in developer_fields.
python3
>>> from garmin_fit_sdk import Decoder, Stream
>>> stream = Stream.from_file(“~/Downloads/Customer.fit”)
>>> decoder = Decoder(stream)
>>> messages, errors = decoder.read()
>>> messages["record_mesgs"][100]
{'timestamp': datetime.datetime(2022, 8, 20, 13, 4, 24, tzinfo=datetime.timezone.utc), 'position_lat': 625675547, 'position_long': -24321767, 'distance': 822.82, 'accumulated_power': 20896, 'altitude': 122.60000000000002, 'speed': 11.859, 'power': 317, 61: 3113, 66: 824, 'cadence': 88, 'temperature': 28, 'left_right_balance': 176, 'fractional_cadence': 0.0, 'enhanced_speed': 11.859, 'enhanced_altitude': 122.60000000000002, 'developer_fields': {0: 21.20000457763672, 1: 14.341415405273438, 2: 100216.453125, 3: 1.1549999713897705, 4: 288.3000183105469, 5: -201.8100128173828, 6: 0.0, 7: -37.479000091552734, 8: 4.5, 9: 2.299999952316284, 10: 42.5, 11: 0.24379999935626984, 12: 0, 13: 0.24039998650550842, 14: 44.661598205566406, 15: 250}}
I'm not allowed to attach Customer.fit so here is a link
www.dropbox.com/.../Customer.fit
  • It is probably not anything that you are doing. We will take a look at the C++ SDK and the file sometime this month and see if we can figure what is going on.
  • I ran your file through the example C++ decode example and there were 299 Record messages written out to the console and 290 of them showed the Developer Field(wind_yaw) along with the rest of the developer data in those 290 Record messages. Is there any additional information that you can provide for how to reproduce this?
  • I appreciate you taking a look! Weird that you see developer fields but I do not.
    Here is how I built and ran the decode example.
    Did I build or call it incorrectly? I'm running on macos v12.6
    cd ~/Downloads/FitSDKRelease_21.101.00/cpp
    # no makefile so I just compiled everything on my mac
    /usr/bin/clang++ -std=c++11 -c *.cpp
    /usr/bin/clang++ -I ~/Downloads/FitSDKRelease_21.101.00/cpp -std=c++11 -c examples/decode/decode.cpp
    /usr/bin/clang++ -o decode *.o
    # try a simple example
    ./decode ../examples/DeveloperData.fit
    # output looks ok
    ./decode ../examples/DeveloperData.fit > DeveloperData.txt
    # try FIT file with 16 developer fields
    ./decode ~/Downloads/Customer.fit
    # developer data names and values missing
    # note https://fitfileview.com shows all developer fields & values
    ./decode ~/Downloads/Customer.fit > Customer.txt
    The output files and screenshot of fitfileviewer.com are in a dropbox directory
    https://www.dropbox.com/scl/fo/6gh9az3mtud4hamswuffv/h?dl=0&rlkey=eme66yejqnc0b83r7057xcvza
