Python: from garmin-fit-sdk import Decoder, Stream --> invalid syntax
Hello everyone,
just a short stupid question from a newbie. I copied the following example from the example site for python code:
stream = Stream.from_file("Activity.fit")
decoder = Decoder(stream)
messages, errors = decoder.read()
print(errors)
print(messages)
But I get an error in line 1 at position 12: invalid syntax
I use VSCode with Python 3.11.0. I tried also at the command line and got the same error.
I installed the garmin-fit-sdk with "pip install garmin-fit-sdk"
I also tried at the command line and got the same error.
From my point of view the problem is with the "-". in the garmin-fit-sdk name.
Sorry for this stupid question bit IO tried allready a view hours.
Thanks in advance for your help. :-)
Best regards
Sabine
