Is there any way to see in the monitoring FIT file or from the device event logs on the actual device that a Garmin device entered into power save mode or was shut down manually?
I'm assuming it is listed in one of the unknown fields on the FIT file but I could be wrong. I've had a crack at the event logs but the format seems to be very hard to make sense of.
The event logs are in this format, I'm assuming that HWM stands for Hardware Miscellaneous with 53 being the event code that pertains to something, is there a list of codes somewhere?
verNum: 8/13/2014 (00)
ownerID: 00000009
OwnerName: CSM
status: 11
pri_thresh: 2
archived: 00
max_arch: 00
num_recs: 05
rec_size: 18
next_evnt: 05
timeDay: 2022/10/ 1 0:30:43
cycle_cnt: 76
00* 10 00 34 00 566:26:58.082 HWM misc 53
01* 10 00 36 00 343:35:09.030 HWM misc 53
02* 10 00 38 00 246:20:17.508 HWM misc 53
03* 11 00 3E 00 415:44:32.002 HWM misc 75
04* 11 00 3E 00 751:12:46.366 HWM misc 75
or:
ownerID: 0000000E
OwnerName: ACT
status: 01
pri_thresh: 2
archived: 08
max_arch: 08
num_recs: 20
rec_size: 20
next_evnt: 15
timeDay: 2020/ 1/22 5:55:06
cycle_cnt: 22
15: FE 01 0E 00 0:06:20.962 HWM main 2019/12/26 20:50:23 V:0
16: FF 00 00 00 0:00:10.056 HWM main 2019/12/26 20:44:13 C:12
17: FE 01 0E 00 0:15:42.722 HWM main 2019/12/26 20:59:45 V:0
18: FF 00 00 00 0:00:10.050 HWM main 2019/12/26 20:44:14 C:13
19: FE 01 0E 00 0:06:33.393 HWM main 2019/12/26 20:50:37 V:0
1A: FF 00 00 00 0:00:09.997 HWM main 2019/12/26 20:44:13 C:14
1B: FE 01 0E 00 0:03:39.288 HWM main 2019/12/26 20:47:43 V:0
1C: FF 00 00 00 0:00:10.076 HWM main 2019/12/26 20:44:13 C:15
1D: FE 01 0E 00 0:24:37.705 HWM main 2019/12/26 21:08:40 V:0
1E: FF 00 00 00 0:00:10.117 HWM main 2019/12/26 20:44:13 C:16
1F: FE 01 0E 00 0:02:47.416 HWM main 2019/12/26 20:46:50 V:0
00: FF 00 00 00 0:00:10.026 HWM main 2019/12/26 20:44:14 C:17
01: FE 01 0E 00 0:01:13.298 HWM main 2019/12/26 20:45:17 V:0
02: FF 00 00 00 0:00:10.036 HWM main 2019/12/26 20:44:14 C:18
03: FE 01 0E 00 0:02:30.954 HWM main 2019/12/28 2:35:33 V:0
04: FF 00 00 00 0:00:08.897 HWM main 2019/12/28 2:35:45 C:19
05: FE 01 0E 00 0:08:06.248 HWM main 2019/12/28 2:43:43 V:0
06: FF 00 00 00 0:00:10.118 HWM main 2019/12/28 2:43:57 C:20
07: FE 01 0E 00 0:01:03.406 HWM main 2019/12/28 2:44:50 V:0
08: FF 00 00 00 0:00:10.077 HWM main 2020/ 1/21 5:06:55 C:21
09* 10 00 00 00 1:53:01.562 HWM misc Update Error. Time between updates: 6780562 ms
0A* 10 00 00 00 1:53:01.661 HWM main Update Error. Time between updates: 0 ms
0B* 10 00 00 00 1:57:28.353 HWM misc Update Error. Time between updates: 7047353 ms
0C* 10 00 00 00 1:57:28.858 HWM main Update Error. Time between updates: 0 ms
0D: D4 00 00 00 8:53:12.334 HWM main Hits Midnight: 2020/ 1/22 0:00:00
0E: FE 01 0E 00 9:53:17.378 HWM main 2020/ 1/21 15:00:05 V:0
0F: FF 00 00 00 0:00:53.301 HWM main 2020/ 1/21 15:01:01 C:22
10: D3 00 00 00 0:00:57.812 HWM misc Time Jump From 2020/ 1/21 15:00:00 to 2020/ 1/21 15:01:06
11* 10 00 00 00 6:08:08.650 HWM misc Update Error. Time between updates: 22087650 ms
12* 10 00 00 00 6:08:09.160 HWM main Update Error. Time between updates: 0 ms
13* 10 00 00 00 14:54:57.021 HWM misc Update Error. Time between updates: 53696020 ms
14* 10 00 00 00 14:54:57.523 HWM main Update Error. Time between updates: 0 ms
