I'm generating FIT Activity files that seem to be perfectly suitable for Garmin upload as well as processing by Runanalyze.com. The FitTestTool can't seem to get past the first 3 to 4 messages before crashing with a Java array index out-of-bounds exception. It declares index 255 to be illegal. From the traceback, line 885 of Decode.Java is:
.... fieldData[fieldDataIndex++] = data;
fieldDataIndex is incrementing wildly. It is as if the logic leading up to this has somehow gotten lost with the number of definition fields I specified and just keeps trying to accumulate more definitions.
FitTestTool's output subsequently claims "Message Count: 3", which has some ambiguity as to which definition message it was processing at the time, but I think it almost has to be the DEVELOPER_DATA_ID definition.
After the FIT header, I have a FILE_ID definition that specifies 6 fields describing 15 data bytes, followed by the FILE_ID data message of 15 bytes, followed by a DEVELOPER_DATA_ID definition for 3 fields describing 37 data bytes. Like so (little-endian):
0e 10 87 08 52 66 01 00 2e 46 49 54 31 45 //FIT Header
40 00 00 00 00 06 03 04 8c 04 04 86 01 02 84 02 02 84 05 02 84 00 01 00 //Define local '0' for global '0' (FILE_ID)
00 01 00 00 00 8a 3d 38 3d ff 00 01 00 ff ff 04 //Local '0' data
43 00 00 cf 00 03 01 20 07 04 04 86 03 01 02 //Define local '3' for global 207 (DEVELOPER_DATA_ID)
03 ... //Local '3' data ...
Is it using some other reference for the quantity of fields it expects for the DEVELOPER_DATA_ID definition message and ignoring the '3' I specified? I didn't find anything in the FIT spec to justify that, nor does Garmin's processing of my upload seem to perform similarly.
I suppose I can ignore it in light of successful uploads, but I was hoping the tool might reveal any other problems with actual content that I might have.
