Hi.
I'm implementing a FIT file decoder, and I think I found some issues with the specification:
1. The endianess used in the File Header (table 1) is not explicitly documented.
2. In the "Normal Header" section (4.1 in the old PDF document), the HTML formatting does not
make it clear that "Definition" and "Data" are subsection.
The same problem is with the "Local Message Type" subsections: "Definition Message" and
"Data Message" (this problem is also present in the old PDF document.
There is also an empty "Data Message Header".
3. When I tried to print the HTML document with chrome, I found that both the document
header (with the FIT logo) and the footer are visible.
Thanks
Manlio Perillo
