Sorry if I missed this in the Q&A or Docs, but I´m stuck a bit:
I have 2 FIT Files with SMO2 Data, one from a Wahoo Bolt, one from a Garmin Edge:
Bolt: In Golden Cheetah the SMO2 data is shown under STANDARD and I can parse it from the FIT File via 'record'->'saturated_hemoglobin_percent'
Garmin Edge: In Golden Cheetah the SMO2 data is shown under XDATA->DEVELOPER and I can not find it if I parse the FIT File
To understand the differences I used the FIT2CSV Tool to export both files. I was searching for developer field or anything that would point me to SMO2, '%' but didn´t find anything.
Here is the CSV from the Garmin:
TypeLocal NumberMessageField 1Value 1Units 1Field 2Value 2Units 2Field 3Value 3Units 3Field 4Value 4Units 4Field 5Value 5Units 5Field 6Value 6Units 6Field 7Value 7Units 7Field 8Value 8Units 8Field 9Value 9Units 9Field 10Value 10Units 10Column1
| Definition | 0 | file_id | type | 1 | manufacturer | 1 | product | 1 | time_created | 1 | serial_number | 1 | number | 1 | |||||||||||||||||||
| Definition | 0 | file_creator | software_version | 1 | hardware_version | 1 | |||||||||||||||||||||||||||
| Definition | 0 | event | timestamp | 1 | event | 1 | event_type | 1 | data | 1 | event_group | 1 | |||||||||||||||||||||
| Definition | 1 | record | timestamp | 1 | altitude | 1 | heart_rate | 1 | cadence | 1 | power | 1 | temperature | 1 | left_right_balance | 1 | |||||||||||||||||
| Definition | 2 | record | timestamp | 1 | altitude | 1 | heart_rate | 1 | cadence | 1 | power | 1 | temperature | 1 | |||||||||||||||||||
| Definition | 0 | lap | timestamp | 1 | message_index | 1 | event | 1 | event_type | 1 | start_time | 1 | lap_trigger | 1 | |||||||||||||||||||
| Definition | 0 | session | timestamp | 1 | message_index | 1 | event | 1 | event_type | 1 | start_time | 1 | sport | 1 | sub_sport | 1 | total_elapsed_time | 1 | total_distance | 1 | trigger | 1 | |||||||||||
| Definition | 0 | activity | timestamp | 1 | total_timer_time | 1 | num_sessions | 1 | type | 1 | event | 1 | event_type | 1 |
Could anyone hint me where to find the developer data or where to read how to obtain these?
Thank you a lot
