DeveloperFieldDefinition in C++ sdk should implement operator= to do a deep copy
To let the following code work correctly, DeveloperFieldDefinition in C++ sdk  should implement operator= to do a deep copy.
//MesgDefinition& mesgDef
//And MesgDefinition has a member: std::vector<DeveloperFieldDefinition> devFields
lastMesgDefinition[mesgDef.GetLocalNum()] = mesgDef;
DeveloperFieldDefinition& DeveloperFieldDefinition::operator=(const DeveloperFieldDefinition& other){
    if (this != &other){
        num = other.num;
        size = other.size;
        developerDataIndex = other.developerDataIndex;
        if (mesg != nullptr){
            delete mesg;
            mesg = nullptr;
        if (other.mesg != nullptr) {
            mesg = new FieldDescriptionMesg(*other.mesg);
        if (developer != nullptr){
            delete developer;
            developer = nullptr;
        if (other.developer != nullptr){
            developer = new DeveloperDataIdMesg( *other.developer );
    return *this;
  • This issue is on our list of things to investigate, but right now there is no ETA. We will let you know when we start looking into this.
    Former Member over 4 years ago in reply to Ben FIT
    ok
  • The operator=() that was missing from the DeveloperFieldDefinition class was added to version 21.47 of the FIT C++ SDK. The C++ DeveloperFieldDefinition class is used by the FIT Objective-C++ SDK as well, so the issue should be resolved in that SDK too. The example C++ encode project was also updated to provide a better example of how to use Developer Fields in the C++ SDK. Let us know if you run into any issues with this change.
