Firmwareversion 2.10 (Edge 800)
Eine neue Firmware-Version ist verfügbar (2.10)
Changes made from version 2.00 to 2.10:
  • Improved Auto Pause behavior.
  • Corrected issues that could cause incorrect speeds to be recorded.
  • Improved auto wheel calibration especially for PowerTap power meters.
  • Added a torque reading to the calibration page for Powertap power meters.
  • Removed DeleteFiles folder.
  • Allow the device to operate in normal mode with external power.
  • Corrected issues that could corrupt activity files which would not allow them to be uploaded to Garmin Connect or Garmin Training Center.
  • Improved keyboard layout, input, and design.
  • Made improvements to the elevation profile.
  • Added an activity reset reminder.
  • Improved how the device responds when the screen has been locked.
  • Added a factory default reset in MENU -> Settings -> System -> Initial Setup.
  • Added the ability to view details for an activity that has not been reset.
  • Data fields should now report correct time and distance while navigating.
  • Corrected issues caused by removing an SD card while navigating.
  • Corrected Auto Scroll issues.
  • Corrected issues drawing the current activity on raster maps.
  • Made improvements to the Virtual Partner.
  • Added memory full warning message.
  • Corrected issue that could prevent activities from being able to be deleted.
  • Route recalculation can now be turned off in MENU -> Settings -> System -> Routing -> Recalculate.
  • Added a day/night color mode setting in MENU -> Settings -> System -> Display -> Color Mode.
  • Sensor settings will now be correctly maintained when merging FIT setting and sport files.
  • Corrected issues with weight scale data recording and communication.
  • Corrected issue that could cause lap calories to be reset after a power cycle.
  • Corrected issue that could cause workouts, courses, and locations to not be displayed in their respective lists.
  • Corrected issue that could cause data field changes on the map or elevation training pages to not be saved.
  • Lap markers in a course will now be recorded correctly while following the course.
Grüße
