Firmwareversion 2.20 (Edge 800)
Fürs Edge 800 gibt es einen neue Software:
http://www.garmin.com/support/download_details.jsp?id=5238
Changes made from version 2.10 to 2.20:
  • Added setting to turn on 1 second recording in Settings > System > Data Recording.
  • Fixed an issue that could cause large jumps in position and distance.
  • Added Last Lap Power data field.
  • Fixed an issue that was causing ANT sensors to not pair as expected.
  • Added a setting to enable a prompt to recalculate during navigation.
  • Courses are now usable with GPS turned Off and a connected ANT+ Speed sensor.
  • The Virtual Partner can now be manually synchronized by pressing and holding on the Virtual Partner graphic.
  • Fixed a speed zone field display issue.
  • Improved course navigation.
  • Fixed issues viewing an activity in progress from the history menu.
  • Fixed issue with some Mac users not being able to connect to device without resetting the timer.
  • Fixed some display issues when using a weight scale.
  • Fixed an issue that could cause distance to not accumulating after switching bike profiles while the timer is running.
  • Fixed a few issues while editing workouts and a display issue while doing a workout in night mode.
  • Fixed a display issue while doing a workout in night mode.
  • Improved elevation calibration when manually setting device elevation.
Grüße
