Edge 510 - Custom Maps - Crash
Hi,
I have an Edge 510 and created custom maps for my cycling area using Mobile Atlas Creator (a great tool for that!).
The problem is that the 510 crashes (turns off) as soon as I zoom in/out, move around or use the map during a ride.
Depending on the size the crash happens quite immediate and smaller maps will run for an hour or two before crashing.
I followed the recommendation - 1024x1024 images and less than 100 tiles plus the correct layer hight (>50) etc.
My current custom map is just around 1.2MB, which works as long as I don't zoom and move much using the hand symbol, but a 4MB custom map will crash the 510 almost immediately.
To locate satelites takes very long when using maps and with large maps sometimes failes completely. After removing the maps, everything works like a charm again.
I updgraded all the way to 3.28 Beta, but the problem still persists. I also did a factory reset, but that didn't help either.
I really like the custom maps feature a lot for my MTB courses. So anyone else having the same problem or some good good hints?
Regards,Sasha
