Edge 1000 software version 8.12 Beta as of May 12, 2016
Notes:
◦This release is intended to fix an issue where an extra activity profile is created when importing settings from WKO4.
◦New feature: this release includes the ability to set an activity's Ride Type. Garmin Connect will show this setting in each ride's Activity Type. You can modify the default setting for each Activity Profile and also manually override this value on the save/discard page for each ride. Please note that the following Ride Type settings are not yet supported on Garmin Connect, but will be added in the upcoming weeks: Commuting, eBike, and eMountain.
◦This release also includes support for four new data fields on the Varia Vision: Gear Battery, Gear Combo, Time in Power Zone 8, and Time in Power Zone 9.
◦Please send any error reports and feedback to [email][email protected][/email].
◦In the process of troubleshooting reported issues we may access information in your Garmin Connect account, such as your activity files. More information about Garmin's privacy policies can be found at: http://www.garmin.com/en-US/legal/privacy-statement
◦Although this software is believed to be reliable, it has not yet been released for production and should be used at your own risk.
Change History
Changes made from version 8.10 to 8.12:
◦Fixed an issue causing an extra Activity Profile to be created when syncing Power Zone settings from WKO4.
◦Added the ability to set a Ride Type for each activity. This setting will appear in each ride's Activity Type in Garmin Connect. You can set default Ride Types for each activity profile or manually override this with another type when saving an activity. The device will also automatically set the Ride Type to be saved as Indoors when the GPS is off (you can also manually override this on the save/discard page).
◦Added support for the following data fields on the Varia Vision: Gear Battery and Gear Combo.
Download:
http://www8.garmin.com/support/download_details.jsp?id=7609
