Garmin Edge 820 - Firmware Version 10.00 Now Available
Firmware version 10.00 for the Edge 820 is now available. This update can be downloaded through Garmin Express or Garmin Connect Mobile when available.
8/28/2018 Incremental roll out: 50%
Changes made from version 9.10 to 10.00:
New Feature: Added Connect IQ 3.0 support.
New Feature: Physio TrueUp for Biometrics. If enabled, recovery time and cycling VO2Max will sync between Garmin devices that support TrueUp. This requires enabling the feature in Garmin Connect Mobile or in Garmin Connect web. To view the current enabled state, a new My Stats Options page is available under Menu > My Stats > Options. Also note that the device will not currently display activities from other devices, even if the help text from other services say so.
Added enhanced support for Varia RTL510 radar tail light. As part of this, all ANT sensor processing code has been improved and should be more reliable.
Functional Threshold Power (FTP) and Lactate Threshold Heart Rate (LTHR) values should be more accurate and in line with other devices now.
Fixed crash that could occur when switching activity profiles in the middle of a ride.
Updated the manual activity upload UI. It will no longer be available if the auto upload setting in GCM is disabled, as this prevents GCM from accepting our upload. If auto upload is enabled, it should correctly reflect success when the upload completes.
Fixed issue where the Edge would no longer connect to old iOS devices after version 9.00's Bluetooth rework.
Added UI to inform users of the impact of brightness and backlight settings on battery life.
Added tip to remind users to remove their bluetooth connection from the phone's settings after performing a forget phone action.
Fixed issue with the device where going into mass storage from a power off state may cause Garmin Express to offer a map update that the device does not need.
Fixed issue where going into mass storage mode would sometimes be detected as an unrecognized device until unplugging the unit and trying again.
Fixed issues preventing device-to-device transfers from completing and made improvements to the connection flow.
Fixed potential crash on the compass page.
Fixed issue where VO2 max could be corrupted.
Fixed issue when renewing the phone connection (not common) would cause the Edge and phone to forget each other after a reboot.
Fixed potential crash when processing audio prompts.
Improved missed call smart notification UI to more reliably show the phone number instead of "Unknown".
Cleaned up some of the sensor found notifications that could occur in the middle of a ride.
Fixed issue where extended display mode could crash when a vertical speed field with meters per second units was configured.
Fixed battery low prompts for radars when connected as a radar and not included in a light network.
    gabs schon den/die ersten Freiwilligen die das Update drauf gespielt haben.
    Nach zwei erfolglosen Updates und "kein koppeln mit dem iPhone" hab ich mich von weiteren neuen Updates distanziert :o
  • Aufgespielt und derzeit keine Probleme
    Hallo zusammen,
    das ist mein erster Beitrag hier im Forum.
    Ich hatte vorher den Oregon 600 und bin vor ca. 4 Wochen auf den Edge 820 umgestiegen.
    Habe mit dem Edge schon über 500 km Erfahrung gesammelt und bin sehr zufrieden mit dem Navi.
    Das Update auf 10.0 habe ich auch bereits aufgespielt und keine Verschlechterung zu vorher festgestellt.
    Gruß Karl-Heinz
    Genau aus demselben Grund (Koppelung BT/iPhone) würde mich das auch interessieren. MIt der 8.4 Version läuft nämlich alles problemlos.
    Schließe mich da mal an... Bin auch zurück auf 8.7 - Gründe ja hinreichend bekannt...
    VG
    Mav
