Firmware Version 11.00 Now Available - Edge 820
Firmware version 11.00 for the Edge 820 is now available. This update can be downloaded through Garmin Express or Garmin Connect Mobile when available.
100% Rollout - 1/10/19 8:50am
Changes made from version 10.00 to 11.00:
New Feature: Galileo satellites. There is now support to use the Galileo network of satellites to assist in getting GPS fixes. With the correct GPS firmware, this option can be enabled by selecting GPS+Galileo in the GPS setting. Sync the device with Garmin Express to make sure that the new line of GPS firmware is provided to the device. Without this, the option will not be available.
Added cycling dynamics support for 3rd party power sensors.
Updated smart notification categories. In the phone settings, social and other smart notification categories can be enabled. This will make the Edge show notifications from other applications depending on how they are categorized by Garmin Connect Mobile. Apps like WhatsApp, GroupMe, and Twitter may show up under social and things like e-mail, calendar, and news may show up under other. These categories are off by default and must be enabled to be seen.
Fixed an issue causing cadence and power data dropouts.
Updated indoor trainer UI to properly disable GPS when activated and no longer try to calculate routes while active.
Fixed issue where FTP data would not be uploaded to Garmin Connect correctly.
Fixed crash when doing a calculation with automotive routing selected.
Added ability to select CIQ data fields on the map page.
Added prompt to indicate when a course has more course points than are supported by the device.
Fixed issue with transmitting front and rear gear information to the Varia Vision.
Added ability to stop the course from the course review page of the active course to make it easier to reactivate a course.
Updated the incident detection interface to better indicate when the user is trying to dismiss the page by holding the specified area.
Fixed crash when using Varia Vision with workouts.
Fixed issue where the GPS data field did not match the GPS indicated by the status bar.
Fixed issue when coming out of mass storage mode that could cause a crash.
Added the current software version to the power on page.
Fixed issues with device transfers.
Completing a segment will now turn on the backlight.
Added a minimum scale to the altimeter page so that small elevation ranges are reflected properly.
Fixed elevation zooming issue with large courses/activities/segments (>100mi or km).
Updated radar tone to be easier to hear.
Minor graphics improvements.
Minor bug fixes and stability improvements.
Minor CIQ improvements.
    Hallo
    seid diesem Update ist die deutsche Sprache verschwunden.
    In den Einstellungen gibt es zwar einen Haufen unterschiedlicher Sprachen, aber deutsch steht nicht mehr zur Auswahl.
    Auch im Garmin Express unter Extras und Inhalt ist keine Sprache wählbar.
    Was nun?
    Danke im voraus
    Sportliche Grüße
    Sportjockel
    Moin,
    war bei mir nicht so, aber Du kannst über GarminExpress die Sprachdateien einzeln neu auf den 820er laden.
    Viele Grüße
    Stefan
    Hallo,
    voelen Dank für die Antwort.
    Dieses Problem hatte ich schon mal, daher habe ich genau diesen Weg gestern versucht. Gestern waren allerdings keine Sprachen verfügbar.
    Heute zum Glück schon, neben Deutsch auch noch andere...
    Sportliche Grüße
