Share/transfer trips from an Edge 1000 to an Edge 1050
Hello, good morning
I am trying unsuccessfully to share routes from an EDGE 1000 to an EDGE 1050.
To do this I follow the procedure indicated in several tutorials, except that in these tutorials the destination device is not a 1050.
Both devices have the Bluetooth function activated...
On the source device (EDGE 1000) I select the option "Transfer between devices", "Routes" and select the routes I am trying to take and accept the selection.
On the source (EDGE 1050) I access the "Garmin Share" function which has been previously activated.
In the tutorials I have viewed, the connection attempt of the source device is shown on the destination device, once accepted the transfer begins.
But in this case it is not like that, since both devices are waiting.
I don't know if it is because both devices are not compatible with each other. If so, can you move them from one folder to another? (I haven't looked into this last option, but if it's possible and someone has tried it, I'd appreciate your help.)
Can anyone help me with this problem?
Thanks again... It's never been so hard to get a new toy.
