Es sollte eine neue Beta geben, allerdings hat Garmin den offiziellen Download noch nicht aktualisiert:
A new Beta software for the Edge 1030 has been released. Full change log, instructions, and software for installing the beta can be found here.
For any issues that you encounter please fill out the form included in the download and attach it to an email to [email][email protected][/email]. Please note that you may not get a response to the email unless we need more information on the issue you report.
Although this software is believed to be reliable, it has not yet been released for production and should be used at your own risk.
Changes made from version 7.00 to 7.07:
Improved connection to the Edge Remote.
Fixed issue causing Connect IQ MapView to not handle inputs.
Fixed incorrect navigation audio tones from the 7.00 update.
Fixed a crash when sending GroupTrack messages.
Added support for 12-speed shifting systems.
Fixed data field issues when using a shifting system with no front derailleur.
Fixed crash when doing the FTP test.
Updated RTL510 and RTL500 light modes for Auto and Trail modes.
Fixed Varia lights not activating when starting an activity.
Fixed issue where radar would not automatically reconnect after being disconnected for more than 2 minutes.
Fixed issue where the Edge would not automatically pair with a radar that is paired to a watch that the Edge is connected to via Extended Display Mode.
Made several improvements to the Sensor Details UI for Vector 3 power meters.
Added support for displaying eBike data fields on a Varia Vision.
Fixed bug in Extended Display mode where Di2 battery would report as 255%.
Installation Instructions
Connect your Edge 1030 device to your computer using the micro-USB cable.
Download and unzip Edge1030_707Beta.zip and place the GUPDATE.gcd file in the \Garmin folder of your device's internal storage drive.
Disconnect your device from the computer, approve the update on the Edge, and wait for the update to finish.
If you would like to revert to the last public release software, follow the above steps but place the GUPDATE-700.GCD file in the \Garmin folder. Rename the file to GUPDATE.GCD before disconnecting your device.
NOTE: If you revert to an older version of software, all of your settings will be reset to defaults.
Sollte dann hier veröffentlicht werden:
https://www8.garmin.com/support/download_details.jsp?id=12819
oder Download hier starten, muss aber ebenfalls erst bereit gestellt werden:
http://download.garmin.com/software/Edge1030_707Beta.zip
